I think my center diff is stuck
Canby Oregon
I got the bug and purchased ( ok I stold a FJ80 97 ) it had no front drive shaft it was removed by the previous owner because of some issues ,also the front axle was replaced ,and since I put a drive shaft on my wheels scrub when I turn there is a clicking sound when I turn ,I tried to get the center diff to lock and unlock do they stay or get stuck some times ??:meh: I need a some help on this thank you
Thank you I did some reading and it seams to be that is it bad to drive it like that or should I just drop the front drive shaft and then when I get home remove the VC ,I have one of the CDL switches
Sounds like a good plan.(drop the driveshaft) Sounds like the front axle needs some work, too. (clicking sound) Sounds like your '97 has seen some use and abuse by PO(s). Welcome to MUD:flipoff2:
Hey thank you for the salute ,yeah it needs a little work but for what I paid it`s ok ,hey brother of the land of mud I go out to redmond alot do you hunt and fish ?? I live on Molalla Oregon ,lots of trails
It's possible that the VC is locked, it can be removed. It's also possible that the CDL is engaged/locked. Is the diff fuse in place/good in the dash fuse box? If so do you hear the actuator motor run when you shift the transfer with the key to run?
No, I haven't since I moved here from Wyoming. Mostly hunted (deer) - here I keep forgetting to put in for the draw. I prefer muley and for that, it's all draw (East of Cascades).
Back to tech - does your diff light on your dash & ABS light come on when you use your CDL switch? You prolly found in your reading on MUD that use of different size tires is what usually fries the VC. If you plan to use your 80 for winter driving, having a working VC is so much nicer for highway driving. As far as wheeling goes, - who cares - if she slips, you engage CDL. Don't know how much $ to fix or replace VC (maybe rebuilt), it all depends on your usage to justify $. If just for wheeling - pull VC and forget it. The 91s and 92s don't have a VC and they do fine off road.
Edit: I see Kevin beat me to the punch. Thanks Kevin! Good helpful tips.
