I think it's time.....
Western Carolina
I have only had my 80 back (long story) for about 4 months and it has been a living nightmare since purchasing it back. I had the thought that since it was mostly built OME heavy/med ARB etc... that I could save some $$ just by fixing what needed, which I thought would be small. Now I have dropped $1500 on an engine, installed it (never do that again) $1000 on a new torque converter and labor from the local tranny rip off joint, it still has a vibration in the driveline that so far has illuded some of the best mechanics I know and it still has a ticking noise from somewhere in the engine. I am at my wits end with this truck, so it may be time to let it go to some teenager or something like that. I think I am done....
What have you done to troubleshoot it? Sounds like you've just thrown money at it.
What's the scoop on it? Lots of pretty good diagnostic types on Mud - let 'er rip.
DougM
Ok, to begin it had a spun rod bearing when I got it, unbeknownst to me until I was about 40 miles away from the dude I bought it back off of. We replaced the engine with one that had 118k on it, it has had a rattle that is hard to figure out where it is coming from. First we checked the bottom end of the engine out, looked at all the rod bearings, and torqued them to spec so we ruled that out, I then thought it was the timing chain slipper b/c it sounded like it was coming from the front of the motor, our toyota stealership replaced the timing chain and slipper....no change. I checked the valve clearances and they were within spec, inspected the shim buckets, and no collapse, they all moved correctly. Then it started vibrating horribly one day, I thought that I had bolted the flex plate to the torque converter wrong, so I unbolted, rotated and re bolted x5 times with no change. I took it to my friends shop to look under it on the lift, when it spilled the entire contents of the tranny on the ground in his parking lot. I had it towed to the local rip off tranny place where they wanted to rebuild the whole thing from the ground up, I told them just to replace the seals and i'd take my chances. Well it turns out the pilot from the tranny to the crank was sheared off and the torque converter was ruined so that had to be replaced with a rebuilt one. After all of this the noise is still there, and it vibrates between 1000 and 1200 rpm's pretty bad, but becomes less after 1200 rpm. Other than those things it drives pretty strong and SHOULD be in good shape. I was thinking that the torque converter might be unbalanced, or cracked flex plate, but the tranny shop says no to both. Unfortunately I have dropped more into it than I have available fund wise, so I am stuck........
Might want to check the motor mounts too since the engine was pulled. Could be where the vibs are coming from?
Replaced 'em when we did the swap....
I took it to my old toyota mechanic ~ 2hrs away who is a Toyota master mechanic with 20+ years experience working on Toyotas,and he is convinced that it is that torque converter not being balanced for the vibration, AAMCO won't fix it, so we are disputing thru the bank (put it on visa for that reason) as far as the noise, since I have changed the timing chain, slipper and tensioner, checked the valve clearance and the bottom end, that only leaves one moving part.... oil pump, but how many of those go bad but the noise is definately from the front of the motor.
distributor/ignition arc sparking causing a ticking noise?
When I changed motor, I put a new rotor button, inspected the distributor, it had no cracks or anything on inspection. Toyota looked at it when they had the timing cover off and it was ok according to them, new plugs/plug wires etc ( the NGK ones not the junky ones) I even followed the schematic in the FSM on how to route the wires under those covers so they are all pretty and organized.
I thought of that too, but when they put the timing chain on, they replaced the idler.... the one that screws into the oil pump....
I know it's probably a long shot, but could the ticking be the idler pulley? I've had some start to go out and they would tick rather than squeel.
off topic kinda but does the idler scream like a stuffed pig??? if so would it have anything to do with the a/c being on or off??? soory for the hijack...
No prob, the idler is brand new so it is noiseless, however the alternator seems to be acting up. I thought it was the battery but I think it may be the voltage regulator because it can go from 10.2v to 14.5 in a matter of seconds, but it is staying low for the most part..... I don't think this has anything to do with any of the other problems, but does anyone have an A343 they want to sell?
Even with all the noises, rattles and vibrations it towed an ~ 1000lb adventure trailer up to 5000' with no problem. Then it drove 50 miles up to the highest point east of the rockies and back for camping and it didn't have any problems other than the starter clicking and it starting after about 5-7 attempts at turning it over.....Perhaps there is hope for this truck after all. Alot of noise seems to be coming from the flexplate/torque converter area..... any ideas on what that might be?
