I really could use your help.
CouleeDamWA, BoiseID
As some might remember I am in the process of working a deal out with a fellow to buy two of his FJ55's. Even after the deal is settled I wont have access to them for some time. Till then I need some help. On my last pig I did some suspension work and took some before and after clearance measurements. But I can't remember where I took the original measurements. At the time I was using 31 inch tires and then went to 33's after the lift. So I need the help of pig owners. I really need to know the info listed below:
1) Front of pig, behind the front spring hanger bracket on the flatest part of the frame. I need the distance from the bottom of the frame to the ground. And what tire size you are running and if you are running stock springs or a lift.
2) In the same spot I need to know how think the frame is from bottom to the top of the frame and if the hanger that the body bushing rests on is the same hieght or higher and by how much.
I wish I could go out and get the measurements off the 55's I am buying but I do not have access to them. They are both running stock suspension and stock tire size. I more then appreciate any help with the measurements.
thanks
dave
O.K., Dave,
I think I can help you here...
1) Front of pig, behind the front spring hanger bracket on the flatest part of the frame. Distance from bottom of frame to ground: About 27 inches. 26 and 7/8ths to be exact. Tires are 35x14.5 Swampers and I'm SOA with stock Pigsprings and maybe a 1" shackle lift.
2) My frame is about 3 & 3/4" think there. The body bushings, you mean the front radiator support body bushings? Yes they are on the same plane (level?) as the top of the frame at the rear of the front spring hanger. Or do you want the height at the body mount at the front doors? (about 28 & 3/4")
HTH
Greg
So if I remember right the original tire size was like a 29" OD. With 35's that would gain about 3 inches of lift with just the tires. So 27 minus the 3 puts us at 24 inches now. SOA on a pig with stock springs... hmmm I think thats at least 6 inches of lift? Cant remember.... so with that and other items Im going to guess a stock FJ55 with stock tires would be about 16 or so inches from the area we measured from.
I thought the frame was taller then 3.75 inches from bottom to top?
The body bushing I was referring to is the one located under the front doors right under the kicker panels.
thanks
Oh. You needed the frame measurements further back?
My bad.
New measurements, just behind rear front spring hanger bracket: about 24.5 to 25" from bottom of frame to the ground.
You're right. The frame is about 5" "tall" in this area.
The body mount, by the front door, is approx. 1.5" lower than the top of the frame.
(top of frame to ground=30" top of body mount hanger to ground=28.5")
hope that helps better.
