I need HELP
Canby Oregon
Ok I looked at all the threads ,I cannot find the one plug showed ,it is a large plug ,I`am at wits ends ,I`am stuck home and can`t get my rig started ,it will not turn over ,my Battery is good ,I `am looking for the neutral switch ,I can`t find that either ,I feel lost this is my DD ,I have no other car ,I need so help it is 97 LC 160,000 miles new starter bat has power ,the starter just hums :mad::mad::mad::mad:,please one of you gurus help me . Hey thanks guys
Hey man. I wish that I could shoot over there and help you... I haven't had to play with this in mine yet, so I'm not sure what to tell you. However, I do have a FSM for a '97 that I would be happy to let you borrow. I know how frusterating things like this are...
Also, you may try posting this at Cascade Cruisers Of Oregon forum as well. There may be a local guy that can help.
Posted up in the other thread and sent you a PM...
Before you start farting around with the connector, did you check to see whether the dash icons (pics in post #54 of the other thread) indicate you have a continuity problem with the NSS? No sense in chasing that issue when a 10 second check will tell you one way or the other based on the dash lights.
Is your starter new or rebuilt? I ask because I rebuilt mine but 6 months later I was getting the no start again...I fubarred the rebuild :frown: - I didn't get the contacts perfectly flush and the plunger started wearing unevenly and would stick...
HTH
More information would be good. First post is kinda vague....
Well I think I have narrowed it down ,I`am going with a start button ,I can jump it across the terminals ,I hope it is just an ignition problem ,I need to get out of my compound :cheers:
Were you able to rule out the NSS?
Well I`am not sure ,I put a push button starter switck because it wold not turn over ,so when I installed the switch ,it started ,but I think part of my problem is the Battery cause it dies fast ,it takes a charge ,but will not hold it ,is there a problem with the NSS draining the battery ??? or do I just have a bad battery ,I started it with my battery charger ,but it still barely turns over ,I`am so fxxxed ,it is my DD and its raining out side and so is my rig :bang::bang::bang: ,could it stil be that NSS ?????????? :mad::mad:
I'm not an expert on the NSS and what exactly it does but I don't see that it could cause the battery to drain...The NSS is a continuity thing.
You need a buddy that can take you and the battery up to get it tested...
