I Need Flex!!!
Krawlerado
OK so i in the middle of my build up and as i play with my flex i find the i am getting no flex (ok a little)out of this 40. what options do i have to get more flex?! and i'd like to stay with springs for now since i'm doing this on a budget.....for now, will be doing air shox and a 3-link but not any time soon. i have heard about swaping out for 60 stock springs and doing a SOA swap but how much flex can i get out of this set up? is there a better set up?
this is what i am dealing with:
1> shackle angles are terrible...
2> you are spring under....switch to spring over with some worn out FJ40 packs, or use some rear FJ55/60/62 stock packs for more wheelbase (97" or so versus the stock 90")
3> post up more pics....front shock mountings, rear shock mountings, etc....a single side pic isn't much to work with ;)
Once you finally do get some flex, you will be self clearancing those fenders. I suggest just going SO with some stock springs as well. That way you shouldn't have to trim to much.
Jeremy
in the back they are cherokee springs. the fronts are early 80s Toy mini truck rear main leaves mixed with wagoneer springs. Wheelbase is 102.5" with no frame modifications. If I got creative with the spring hangars I could get it out to ~104 without stretching the frame...
SOA and stock springs do wonders for flex.
