I need a little help please
As you guys may remember my FJ40 has had some troubles running at highway speeds,bucking and what not. It always looked like i had gas in the viewing glass but i was wrong. I took the top of the carb off today and i only had about a 1/4 of an inch(if that) of gas in the carb. Would that make it maybe run out of gas while going down the road when it needs more gas?
Anyways my big problem is now it wont idle at all. It'll run with the choke on or while patting or holding the gas peddle down but dies when no gas is given. Im asuming it has something to do with the float. Where in the dickens is the needle valve at anyways. Also i has a time getting the plunger( dont know what its called) thats close to the valve cover back in but it seems to function right. What have i done wrong here guys and do you thing the low gas level is my problem?
Have you verified your fuel pump is 'pumping' and that your fuel filter is clean? Start easy and go from there. I'm only a 1 :banana: person so I can't help you much re: the carb. Other possibility could be gummed up tank but IIRC the symptoms for that are usually starts and runs then dies as all the crap gets sucked back to the pickup point in the tank.
GL!
If you have not changed your fuel filter then do that first. Then disconnect the fuel line from the carb. Have someone hold the line into a jar or other fuel holding vessel while you turn the engine over. You should see the fuel spray out if your fuel pump is good.
pull the fuel line before the pump, and have one of your buddys blow :D
Sometimes debree in your tank can make it's way into the line and cause high-speed issues...
As stated above, your FP should also be checked.
Yup the pump is good and it has a new filter. Originally the problem was it would buck and cut off at about 30mph. So i just figured i'd take the carb off and take a look at the gas level since i didnt see any in the sight glass. So i put it back together and now something is bad. It always idled perfect and ran around the farm with no problems at all. only on the highway it would buck like it was starving for fuel.
Mr Manny u posted at the same time i did lol. I've done that also. It also has new plugs,new wires, and a new distributor cap.
This may sound silly but check your fuel tank vent. If it is plugged or partially plugged it will not allow air or enough into your tank, therefore your carburator will starve for fuel.
This would be really unsafe but try driving down the road at highway speed with your fuel cap off. If the problem goes away you know its your tank vent.
I had a problem like this that was due to an incorrect adjustment on my carb float, just like you suspect.
There was only a little fue in the carb bowl, so when the engine was under load, it would suck it dry, and the thing would be starved for gas. The float has a little metal tab that touches the needle valve. It needs to be bent so that when the float is most of the way "up" in the carb bowl - it pushes on the needle valve to close it.
You might also have some crud in the needle valve, partially plugging it.
Good Luck.
Rocky
What is the condition of your carby? Sounds like you have dirty fuel issues etc.
Thought of putting a carby kit through it and starting from factory settings again?
What sort of Carby? Stock or other?
Don't know on the high speed problem but the idle problem sounds like your fuel idle solenoid. There is a 12 volt wire comming off the carb. Jump that to 12 volts and you should hear a "click" (or turn on your key and listen for a click)
I just had this problem with my fj40 f-engine. Must have been over 4 splices and a crusty connection. Solenoid did not click when key was first turned on, so I jumped it to the battery and all was good. Just cleaned up all the connections and soldered them all up and all was right in my crusier world again.
But I had the exact same engine responses as you described at idle.
Its the stock carb first of all. Im sure its never been rebuilt. 105k miles which i dont think makes it that bad but probably does need rebuilding. It did have some bad gas in it a while back when i got it so maybe i havnt gotten the gas completly clean. The solinoid does sound like maybe it could be it. I'll check it tomorrow maybe i pulled something loose when i took the top off. I didnt have time to play with it today. Anyways thanks guys any more help is appreciated.
Okay checked the fuel idle solinoid this morning. it checks out good. I can turn the key on and unplug and plug in the green plug and here it click everytime it makes contact. When looking at the fuel in the sight glass its 3/4 of the way up. Could to much fuel in the carb cause this problem?
It only gets better.
Took the top off yet again and now i have nothing. If i pat the gas enough it'll fire up for a second or with the choke on run really rough. Man im so upset lol. Do you guys think this is coincadintle and its something else or it is time to rebuild the carb. If so what is the best rebuild kit to get?
Don't forget to check for vacuum leaks. Carb. base to intake and intake to head. Leaks here will inhibit the engines ability to draw fuel from the carb. Making it necessary to pump alot of fuel or use the choke.
Leon...
You say that it idled fine before you pulled the top off the carb? Well, a few years ago I had the same problem on my 1970 FJ40. As I recall, my engine ran fine until I let it idle, then it would slowly die. The problem I had was when I removed the top there was some sort of check ball that fell out, it basically looked like a BB. Anyhow, once I found the check ball rolling around on the shop floor I realized what had happend, pulled the top reinstalled it, and it ran normal again. Also, check to make sure you solenoid is still working.
Oh nice
and to know i took the top off in the middle of the field. Im guessing the check ball must go on top of the little metal thing thats kinda spring loaded that is about 4 oclock to the accell pump if the accel pump is 12 oclock. Nice i'll never find that. Is the part included in a rebuild kit? I may just buy a kit just to put the accel pump piston thingy on and the top gasket. I believe thats the verdict. Thanks
According to SOR theirs a check ball underneath the accel pump. Is this the one you're talking about. If so i cant see how that would be my problem as i never took anything out underneath the accel pump except the piston/pump part itself. I never took the spring or retainer out. Is their a different check ball or does it somehow just come put with the top off of it? Thanks
I think im getting closer!
I was looking at the top gasket today and noticed beside the accel pump a big piece is missing out of it. I would imagine that would cause a major vacuum leak am i right?
I've had a very similar problem. It turned out that one of the main carb hoses was completely blocked with carbon and wasn't allowing passage.
