I messed up-RL Water Wetter in Gas, now white precipitate..
Driving
Hi all,
I thought I was adding cleaner boost and instead added the coolant treatment 2015 570. Filled up with ethanol gas drove poorly, added two yellow heets, worked better and then just runs at idle/low speed. Get a dual bank lean code. Pulled the fuel pump and there is some loose white precipitate in the tank (2x2 patch) and just a little around the pump (soft floc). I pumped down 14 gallons and am close to the bottom. I can see the junk, but obviously the tank is convoluted so hard to see everything. Should I send this to a shop or is there some way to safely flush the tank from the top? TIA
Have you dropped the tank already?
Tank still in covered with armor. Was able to pull pump and that internal screen has some of the precipitate. I'm replacing that.
