Good morning Gentlemen and I am sure a few ladies,
I have recently taken stewardship of fine steed, a 1993 Toyota Land Cruiser fzj-fe. I have been asking a few questions as I work to get the vehicle sorted. However I think that it would be best to inform the council of the history of the vehicle so that I may enjoy the most informed wisdom.
At around 360,000 miles, the vehicle blew a head gasket and was subsequently parked for a couple of years. Eventually an enterprising young man picked it up and pulled the engine. A new long block was fitted and the head was rebuilt. The truck was then put back together. The young man then drove the vehicle for approximately 6 months. He then sold it to me.
The vehicle did not run well. It seemed to be idling fast and missing. I set about searching for the leak and found the hoses to all be old. I replaced all the hoses I could get too and I replaced the ICV and the TPS. I pulled the throttle body and found it to be filthy, so I cleaned it. I adjusted the throttle cables, as they were holding the throttle open. This corrected the high idle but I found the truck to run extremely rough and belch dark sooty clouds, staining my driveway. I checked the timing and it was never set. The distributor was just tossed on and the timing was off by perhaps 30 degrees. After adjusting the timing, I checked the oxygen sensors and they were completely covered in soot from the incorrect timing and weird throttle position. I also messed with the golden screw on the MAF not knowing what the previous owner may have done.
The vehicle seems to run okish now. I drive it around with out worrying to much. Occasionally it dies when coming to a stop, but starts up again without trouble. It has a loping idle of perhaps 250rpms when cold and might take two cranks to start. It is slow off the line (it was a bit faster before I started setting things right, but ran much rougher, with poor on highway performance) but it happily does 80mph. My oil pressure is extremely high and occasionally the truck shakes when idling in gear. All of these problems are intermittent though. I am thinking I must pull the engine, though I am louth to do so.
in short, new engine, everything else worn, old, poorly adjusted and filthy. Where does the council recommend I start?
-new TPS ( I am sorry, it was off brand, I think I might have to get the Toyota one)
- new ICS (Toyota)
-correct timing although a occasional misfire was noted while setting it
- egr system was deleted somehow, I am not sure what he did, looks a bit shady
-new coolant temp sensor
-New uptake hose
- New PCV valve and gasket (valve cover inside was filthy with oil scum.
- new ICS (Toyota)
-New uptake hose
