I got’s the shakes
I have steering wheel shake when I give slight to moderate pressure to the steering wheel
straight and hard pressure it goes away.
I checked all tie rod ends they are tight (no play) checked the knuckles for play, no play
there ether.
I have 33” yokohama geolander’s that were balanced over a year ago about 50% tread
left now. I noticed that they used only hammer on rim weights in the inside because
there is no lip on the outside of the rim.
Also I have what feels like slightly warped rotors.
Are these issues most likely the culprit?
This happens without using the brakes, at speeds above 25mph.
my best guess is it’s the way the tires were balanced, but not sure
because it didn’t start till about 50% tread.
Check the balancing, but it would have to be pretty bad to notice it anywhere around 25mph. Definately have your rotors turned if you know that they are warped and try to find out why. Most rotors that become warped don't just do it because of age, you may have a stuck caliper which could cause a vibration while driving.
Kevin
The rotor warpage is caused by my driving, to fast on curvy roads.
Once I hade almost complete brake failure, I could feel it in the peddle
first so I was prepared.
It happened to a friend in the exact same spot too. He was also driving
a lifted Yota.
Bearings are tight (insignificant amount of play)
I have the same problem... but my rig is grounded till i do the axle rebuild and stop the pinion from leaking.... let me know if you find out what it is... i'm thinking tires
I took off my wheel weights and the shaking got worse so I had my tires rebalanced and it almost completely went away. Tires are about 50% tread and it took less weight this time.
I do have a slight shimmy when I turn but I believe this is due to having all the weights on one side of the rim
shaking
I just replaced my rotors this past weekend and my shaking has almost all but gone away. I will continue to monitor but my shaking was only when braking.
