After 10000 miles of not worrying about it I finally went searching yesterday for the source of the metal chunks I found in my oil pan. (https://forum.ih8mud.com/diesel-tech-24-volts-systems/233005-oh-no-metal-oil-pan.html)
You may recall that my oil pressure, which was in spec but not stellar, had been falling a bit and was now just below spec (https://forum.ih8mud.com/40-55-series-tech/274235-low-oil-pressure.html).
And you may also recall that the diameter of the chunks hinted that they might have come from a cam bearing, and that I took a wild guess that it could be the front bearing, given that the front two rockers had bad divots in them (perhaps from a cam that was wobbling a bit)...
Well it turns out that sometimes even wild ass guess are right!! Some pictures, which should be helpful for anyone pulling a camshaft:
1) Getting at the cam sucks, you've gotta take a lot of stuff off! If you're me, you even have to take the oil pan off, more on that later
. At the very least, grill/bib, radiator, air cleaner, rocker cover, side cover all need to go.
2) Crank pulley has to go too, I didn't need to use a puller this time, was actually able to pull it off by hand.
3) I was worried about the automatic timer, which the FSM says will come away attached to the timing cover, and that there is a timing cover heating process that should be used for getting it back in and out - seemed like a pain. Turns out that my timer stayed on the pump when I pulled the cover, so it was moot!
. At the very least, grill/bib, radiator, air cleaner, rocker cover, side cover all need to go.2) Crank pulley has to go too, I didn't need to use a puller this time, was actually able to pull it off by hand.
