Pulling the pin on the hand grenade and tossing it.....
Anyone here heard of KCLV? I've got an IS F and I read about KCLV on an IS F forum. Lots of talk about it there, where you find many guys dragging and racing their IS Fs and looking for max performance. For those of you who haven't heard of it, KCLV stands for "Knock Correction Learn Value." On the IS F, it is simply a long term ignition correction factor. After you flash your car or reset your ECU, the KCLV goes to 15. Once you start driving the car, particularly doing long pulls at high load, the ECU starts bumping the KCLV up in small incremental steps until some knock is detected. It then backs it off, and leaves you with optimally-advanced ignition timing.
The value is apparently continually adjusted, based on octane, driving style (engine load and RPM) and other factors. It also appears that the IS F guys use Techstream to flash (reset) their ECUs when they think they've lost a high KCLV and/or are going to the track. Rather than using Techstream, some guys disconnect the battery, and some just go blasting around at WOT for a while to ease it back up.
For some reason KCLV popped into my head this morning as a possible partial answer to a number of questions often raised in this forum, e.g "Why does the LX require 93 octane and the LC doesn't?", "Why is the LX spec'ed at 1 more HP than the LC?", and the big one: "Why buy premium???"
Many have answered these questions with some variation of "It doesn't matter, the ECU will accommodate the variation in octane so don't worry about knocking. We have a modern engine."
All that said, has anyone noticed KCLV in Techstream or on an OBD2 dump? I won't have time for researching this any time soon, but I wonder if the LC/LX uses KCLV, I wonder if we really will realize some degree of increased performance if KCLV is increased (regardless of how), and I wonder if the true answer to the octane question is "Yes, you will eventually achieve slightly better performance if you keep using premium, and yes, we told you LX owners you could make more horsepower if you kept buying premium, but so will the LC owners."
I also wonder how around town driving vs highway towing affects KCLV and overall engine performance. Lots of evidence in the IS F forum clearly shows stop and go, easy around town driving results in a reduced KCLV and reduced engine output, therefore the reflashing before racing.
So, there's the grenade. Nothing really earth-shattering, but I know how we all love/hate to talk octane. At the very least, this might be an interesting topic for discussion.
Your thoughts?
Your thoughts?
