Sounds like you have smashed your stock box and you're able to replace 80 series box.Hi, how near is the low gear stick to the handbrake location in L4? And is the speedo accurate? Thank you.
Wong, my transfer box rear output shaft had broken. I thought the common problem of r151f is input shaft. A friend of mine had h150 in 75, L4 is very close to the handbrake and the speedo is bouncing all the time (maybe due to different sender between h55f and h150). I wonder how does it goes in 79.
I think oxy the transfer gear shifter will be the best way to solve it.You need some minor mod for a H150 box to slot in 79 and not knocking the handbrake.
Bouncing of the speedo in 75 is because of the cable is old enough to replace whereas 79 is an electric type speedo.
In that case, you have to search for hdj79 gearbox from australia.My way is as factory as possible and not involving oxy.![]()
