hydrogen-boost
Las Cruces, N.M.
Anybody try this?
I have a friend with this system (paid $250) mounted in a Taco. Without tuning claims better horspower.
$900/kit now seems alittle steep for pocket. May take awhile to recoup that kind of dough.
Anybody test these out on the F/2F's?
Company has diesel kits as well.
Sounds pretty cool if it works as they claim.
http://www.hydrogen-boost.com/index.html
And yes, I did a search with no luck...:D
I looked at the system on the web. I would be very careful about buying such a piece. Most of it looks like parts your would pick up at Home Depot. A lot of plastic tubing and PVC pipe. I have run across a llot of similar devices in the past that claimed everything from increased mileage to boosting your sex life. Just my 2 cents.
Hmmm uses 20-30 AMPS of power. That's the total output of my alternator! Subtract the load the alternator is going to place on the motor from the gains by burning the hydrogen and I bet I would break even and be $900 poorer...
If it seems too good to be true....and why wouldn't manufacturers, who have billions if not tens of billions of dollars to work with, have already done this if it worked?
Not to mention the additional wear on your Fetzer Valve.:)
Ed
that's funny. It's a perpetual motion machine. Think about the process here. Were going to use engine power to create electricity, use the electricity to seperate water into hydrogen and oxygen, then burn the hydrogen and oxygen ie chemically combine the same molecules we just seperated into water vapor and somehow create energy? violates the laws of thermodynamics. I understand that it may be changing the nature of other processes but I really don't see how there could possibly be a net benefit. If it really worked we could just eliminate the gas and run on the hydrogen. unlimited mileage.
Interestign idea; though one wanders when these ideas change from honest belief to knowing they are bad and becoming fraud?
THere's a great book called vodoo science about just this sort of invention. It reads like a novel but is a very interesting look at misleading science.
edit: after thinking a little more about this, it could theoretically be possible to use hyrdrogen as type of hybrid technology where the breaking uses magnets in drums inside the rotors primarily to create electricity which is then used to seperate hydrogen and oxygen when breaking. This could then be reintroduced and burned when needed. If it worked efficiently it may be better than storing entergy in a bunch of expensive batteries that will eventually die. Could probalbly draw moisture from the air to use instead of filling up water too, but how much $ is it worth? coudl also have a seperater in the exhaust and reuse the same water over and over.
