Hydro assist, see if my mount looks okay
Seattle, WA
Mounting a 6" PSC ram on my SOA FJ40 with Histeer conversion. I've got the ram mounted about as parallel to the tie rod as I can get it. I've already added an internal spacer to the ram to limit its range to a bit shorter than the full travel of the tie rod. I'm using a clamp style mount on my tie rod. My only concern is that if the tie rod rotates it'll run the risk of the clamp hitting the spring pack.
Can you folks take a look at the pictures and let me know if it looks okay? Just tacked into place right now.
will it clear the crank at full stuff?
I think the idea is to have the Steering knuckles, Ram, and box all Reach their limit at the same time, this will share the load evenly between the parts.
in my case it does .. gotta note I'm still at spring packs so not huge uptravel suspension here ..
