You can make mounts off the frame to mount bump cans, tube, plate, whatever. You can weld the can straight to the frame and maybe make some gussets or not, you can french the can into the frame. Then your bump pad just has to be large enough the air bump won't slip off. You don't have a whole lot of articulation to worry about but your axle is going to move a little side to side under articulation so depending on where you put your bump (like how far out above the axle) you'll be hitting a different point on your pad during full articulation than full stuff both sides. People mess this up and sometimes the bump can slip off the pad and then you can rip you air bump out of the can or bend a shaft etc... So your pad needs to be big enough and you need to test it all after you tack it in. Take out the springs and cycle your suspension if you have to.
Umm you probably only need a 2.0 diameter bump. 3" is a good choice IMO but like I said if you don't have much up travel, say 4", with only an inch between the pad and your bump you'll be tapping that air bump all the time which gets annoying. I'd say give yourself nearly 2" of travel between the pad and the bump, so you'd then have another 3" of up travel but it'd be progressively limited by the air bump, which works pretty well actually.
This chart made a liar out of me so another thing is maybe see what you can fit. Can you fit a 13" extended air bump? If you're finding packaging to be a problem look into the jounce shocks, they're kinda similar but way more $$ but they're a lot smaller.
Part # Description Travel (in) Ext. Length (in) Col. Length (in) Oil Volume (cc)
FOX-983-02-091 2.0" Air Bump Stop 2.0" 9.66" 7.66" 100
FOX-980-02-311 2.0" Air Bump Stop 2.5" 11.00" 8.50" 100
FOX-980-02-323 2.0" Air Bump Stop 3.0" 13.10" 10.10" 125
FOX-980-02-022 2.0" Air Bump Stop 4.0" 14.10" 10.10" 125
I've seen some jounce shocks that would mount where your bump is on your 80, but for jeeps, that may be worth looking into as well. Not sure though.
Theres really not that much going on with the 80 series suspension, there's bound to be room somewhere you're just going to have to do some fab work to mount them up.
Also your bump pads don't have to be identical just make sure you mount the bumps so they hit at the same time on either side. Also if you end up having one bump on the inside of the frame and one on the outside or whatever... keep in mind that during articulation they will hit differently. FOR instance I don't really touch my air bumps during full articulation but if they were mounted farther out I probably would.
My bumps are actually in different spots on each side of the frame. One is farther back on the frame and hangs down lower but it hits a pad welded off the back of the axle. The other hits the top of the truss and is mounted farther up. So you can get a little wild just keep in mind the arc of your axle as it moves through it's travel and make sure they both hit at the same time under full stuff.
