All,
Over lunch, I noticed that there are several winches listed at www.govliquidation.com which are take-offs from Hummers. They are located in AL at Redstone. The problem is the information included on these winches in the descriptions. The title says they are Mile Markers, but the NSN block says they are 24 volt Warn. The included pictures shows a Mile Marker name plate and a mounting bracket with the Mile Marker cage code. The following is the link to the page with all the current auctions in AL.
http://www.govliquidation.com/auction/endecaSearch?Ntt=USAL&Ntk=P_Auction_Country_State&Ntx=mode+matchall&N=0&Nty=1&Ns=Lot%20Number|0&location=US_AL&cmd=keyword
If they are Mile Marker hydraulic winches, aren't they a solid winch but very slow? If they are Warn, won't they be 24 volt under rated at 6000lbs? (i.e., their capacity is much higher than the rated 6000lbs?)
I posted this for this keen eyed crew to ID which winch these truly are and educate me. Plus there may be some interest in these winches by others.
Thanks
Thanks
