Hub Removal
San Antonio TX
I'm trying to remove the mini hubs from the axle to continue my disc conversion and I can't get the *(&^(&*( things off. I've used a rubber mallet, trying not to beat it to death, a block of wood and a bigger hammer, hitting the face of the hub hoping to break out the acorn washers and generally just beating the crap out of it with no luck... any idea's? throw'em my way.. I'd like to get at least 75% of this done this weekend. My goal is to remove the mini parts and rebuild them and get them ready for install on the cruiser. I just gotta convince the little lady to leave me alone !!! ha
By straight away you mean towards the outside of the axle? forcing it out? I cant get a punch on the darned things, tried screw drivers, chisels etc. If by chance they are rusted on, would PB Blaster break them loose after soaking overnite? If I screw them up too bad, will the ones from the cruiser work?
kbill's got the idea, but use a brass drift instead so you don't f-up the studs. Line the punch up straight on like you're going to drive each stud into the hub (parallel to the axle), then whack em good. The shock will loosen up the cone washers, and as pygpen says they sometime do fly. You may have to hit them a number of times, but keep at it, they'll come.
That's the way. Brass drift straight-on on the end of the studs. Probably wouldn't hurt to hit 'em with your favorite penetrating stuff, and be sure to clean all the crud from the surface so that you can see the cone washers move when they finally let loose.
I have had success with both smacking around the outside of hub with a 3lb brass hammer and also placing a brass drift in the center fo the hub and smacking it repeatedly.
It does take some force.
by acorn washers you mean cone washers?? I always smack the side of the hub body right next to the cone washer.... leave the acorn nut on or the cone washer will fly to the farthest reaches of your garage!
PMK
Yeah, you know, when things don't go right and you have beer nearby, it helps in the healing process... OK, don't laugh guys but this is where I show my ignorance. What do you mean by a drift? I may have one and call it by another name but haven't heard of one.. I'll continue smacking tomorrow,
Thanks for all the help...
Example..
Drift? Punch? the only pic I could find....
Man! that pic in post #9 is a good example of a clean work environment:eek:
I have the best luck, by giving, a good whack on the side in the area of the dowel pin locations............
Example..
NOPE, not even close to what I thought it was. It's true when they say you learn something new every day. Especially when dealing with cruisers.... Like yesterday, I learned you should wear safety glasses when working on hydraulic hoses. The hose blew on a batwing mower I was working on and I thought all of the pressure and fluid had bled down but, when I removed the hose it blew more fluid all over the place, especially in my eyes! I couldn't see for a few minutes and when I could it was like looking thru glasses with vaseline all over the lenses. I made my way to a water spigot and rinsed them out, got a little better and did it a few more times throughout the day. It's still a little blurry, hope it clears up!!!
MY 2cent worth: 1. clean area with penetrating oil and blow air
2, loosen all nuts- level nuts at top of stud (( do not remove nuts completely)
3, do #1 again
4, hit top of stud/nut with a brass drift- (be sure your brass drift is 2x the diameter of stud) squarely with a firm strike and work on it diagonaly. youll find cones will come popping out and the nuts prevent the cones from flying out/ruining the threads on the studs. On some times, studs need to be hit 2x or 3x
Good luck.
I like this board. I really do, but, I've come to the firm conclusion that you all are a bunch of liars!!! It took me all damned day to get the cone washers out of the hub housing. I'm telling you I hit it with a dead blow hammer and drift over the stud as mentioned, I hit the cone washers at an angle with the drift and just generally beat the crap out of the housing with no luck. I hosed the damned things down again with PB Blaster, let them sit about 3 beers worth and went back at it. The first damned swing I hit my thumb crushing it against the axle so, back to the beer but this time to keep my thumb from throbbing. Two more beers later, well, I had to drink them before they got too warm, I started again only this time I got all but one of the washers out. I beat and beat on that SOB like there was no tomorrow but it finally gave in and released but, there was something weird about this one, I had to thread it off the stud not slide it off like the others. I may have hit it a little too hard but it deserved it. I thought I would let you guys know the progress I'm having with this project and how good your advice is working. Maybe some of you are at home laughing but I assure you my thumb hurts like hell and I have to put a hot needle thru the nail to relieve the pressure because I'm running low on beer. Serious tho,,
Will the cone washers from the 40 work in the mini hub or should I buy new ones?
Thanks for all the help and I am taking pics for the Disc Conversion For Dummies, Like me !!!!
Kevin
Try it next time without the deadblow hammer... I use a regular one, and if they're ornery I bump up to the 5lb hand maul. A WAG but suspect the deadblow was minimizing the "shock" that makes them pop loose.
Can't help you on hitting your thumb other than suggest not doing that... :-)
yep 4 sure
Yeah, the thumb impact was a result of being frustrated at not getting the damned things to pop out. I did try a regular claw type hammer but I was hitting it so hard I was damaging the ends of the threads by pushing the bolts down on them. I changed to the cone washers and was trashing them. I think they were just stuck due to sitting for about 3 years w/0 being used at all...
