Hub-mounted spacer to replicate IFS hub offset for slip-on rotors — viable alternative?
Hey everyone,
I’m working on a front brake conversion for my 40 series Land Cruiser (Latin American spec). The truck has fine spline outers, but still runs front drum brakes, so I can’t directly use IFS hubs.
Because of that, I’m currently looking at three options:
  1. Swap to FJ60 outers
  2. Run a ~1.5"–2" spacer to move WMS and simulate IFS hub offset
  3. Design and manufacture a hub with the correct offset
I’m particularly interested in option #2, but not as a typical wheel spacer. The idea is to use a precision spacer mounted to the hub flange, effectively becoming part of the hub, to replicate IFS geometry and allow a slip-on rotor setup:
  • Wheel
  • Slip-on rotor
  • Hub-mounted spacer (fixed)
  • Hub flange
So, the rotor remains slip-on (IFS-style), and the spacer defines the offset.
Questions:
  • Has anyone run something like this long-term?
  • Any issues with runout, vibration, or heat-related distortion?
  • Is this a reasonable alternative to a custom hub, or not worth it?
Trying to balance cost vs. proper engineering. Any real-world experience is appreciated.
Thanks 👍
I am not familiar with the design that you are describing. But I am familiar with logic. And logic says that a slip on rotor may be more convenient. But a bolt on rotor would be safer. And I am not inclined to choose convenience over safety, especially when it comes to brakes.
A rotor that is not directly bolted to the hub will exert force directly on the wheel studs. Adding a spacer would caused that force to have a fulcrum. I don’t consider that safe. Even if there were no other alternative, I would think more than twice about building such a thing.
In my experience with SA rigs, if you have fine splined birfs, you may already have knuckle housings with the ears for hanging disc calipers. So the conversion would only require the disc hub, spindle and calipers.
Thanks for the input, I appreciate the concern regarding safety.
Just to clarify, the setup I’m describing is not relying on the studs to carry braking loads in the way a typical wheel spacer might. The rotor is still supported concentrically by the hub (through the spacer acting as an extension of the hub flange), and the clamping force from the wheel keeps everything seated as in a standard slip-on IFS design.
That said, I completely agree that concentricity, surface finish, and proper preload are critical here — this approach only makes sense if those are tightly controlled.
Also, in my specific case, the truck is a Latin American spec 40 series. While it does have fine spline birfs, the knuckle housings do not have caliper mounting ears, so I can’t just bolt on a typical disc setup using later components. That’s what led me to explore alternative solutions like this one.
Appreciate the feedback 👍
