Hub housing question
NC
Got a question about what i am assuming is the hub housing ( least what SOR calls it ). It is the part the actual lockout hub bolts to with 6 bolts. It has the actual inner and outer wheel bearings in it, guess that ought to explain it well enough.
Anyhow onto the important question. I have a 3 / 75 fj40 with drum brake front still and need to know what is the latest year i can replace the one that is on there. I broke 5 of the 6 bolts off this weekend but not the lockout. SOR shows all the way from 58 - 9 / 75. Is that correct ? Reason i ask this is i have a 78 front already taken apart, or i can take apart a different older axle to get to an earlier model one. Got to build it today or tomorrow, going wheelin again this week.
TIA
Why don't you swap in the 78 knuckle out components. Then you'd have disc brakes instead of drum.
I am trying to do this quick so i can go back to the woods this week, and free with no mods. My brakes work perfect the way they are. Actually almost too good.
My next "Budget" reply
Have tried eazy outin' the broken bolts in the hub. I had the same problem on the trail, worked easy enough for me. Otherwise, I'll bow out and let others chime in.:cool:
I've got both the later and earlier ones handy, just the later is much more handy, and if i can fix this other one on the truck later then will have another spare. Thanks though.
The 78's won't work for you unless you swich all 78 parts. While the external dimensions 'may' be the same, I do know the internal dimensions are different as the Sept/Oct 1975 and on have a fine-spline birf that has a larger shaft diameter. This necessitates different/larger bearing/race.
If you truly need a drum brake part there are lots of people out there that have converted to minitruck disk brakes and have the old drum brake stuff collecting dust. I got so sick of moving them out of my way I eventually ran a post in the for sale section offering to GIVE the stuff away for the cost of the ride. I got all these people asking me to estimate freight to CA, OR, WA. WTF, it's free man! I found someone local that was not necesarily the first to respond, but was the first to pick it up.
Look/ask around. You might be able to find someone giving it away.
Take the earlier one apart and use it. I do not believe the drum and disc hubs are interchangeable.
Thanks guys, thought it was different between the drum and disk. Got the old one off already, getting ready to tear into to the good one and use it for this week, then going hunting locally for some more.
