How to remove, parking cable...pic
Bakersfield, Ca
Can I release the cable to work on all this on the bench or does it all need to be dis-assembled under the truck?
I know there's a clip on the one side but how do you unhook the cable from the other?
Pull the spring on the cable back and lift the end of the cable out of the lever. It's easier if the adjuster and springs return springs are out.
Right, the cable sits inside a hook on the lever, so remove the clip, then push it in to get it to slide out of the lever.
