How to remove headlight washers
Atlanta, Georgia
Headlight washers work but the passenger side is spraying up instead at the headlight so I was going to swap one out. Couldn't find instructions on how to remove them though in the forums. Anyone ever try doing this, don't want to break anything? Anyone know if the plastic nozzle portion can be replaced easily?
Thanks.
It's held on with two nuts clamping it from inside the valence (I think). The rubber extruding thingy that holds the squirter has two studs embedded into its mounting face (I think).
See attached picture. In this picture I covered the bolt holes with small bolts to hide the holes, since I got rid of the washer entirely. The big hole in the center is for the water tube.
IIRCC the nuts are attached to the valence and it has 2 phillips screws holding the unit to the valence.
you will need to remove the spring clamp thing on the backside by the check valve to get the hose to come thru the valence
I probably have photos since I removed my valence last summer and had it powder coater but I’d have to do some searching to find them. Lmk if you need me to. I do remember those philip screws being in super super tight.
