I need to replace the weatherstrip on the rear tailgate of an '05 lx470 (the weatherstripping that goes all the way around the rear opening - not the upper/lower door weatherstripping, but the body's weatherstripping). I've already got the replacement piece - my question is how is it supposed to be installed? Am I supposed to use 3M Super Black WeatherStrip Adhesive (or equivalent), or does it just go on without any adhesive (it appears to be the push-on weatherstripping)? Also, where do I apply the adhesive - just on one side (facing outside of car) of the flange, just on one side of the weatherstrip, on both the flange and weatherstrip, in the channel of the weatherstrip that fits over the flange, flange + both sides of weatherstrip + weatherstrip channel?
Apologize for all the questions but I'm new to this and already made the mistake of reapplying the weatherstrip with silicone RTV. Now I'm trigger shy and want to get it right.
I had leaking in the rear that wet the carpet. Step 1 I got the 3rd brake light replaced with OEM + aftermarket rubber gasket (apparently the OEM part has a crappy foam gasket). The leaking got way better but still had a leak from the weatherstripping that came in by the XM wire on the top of the weatherstripping and seeped down the side and into the rear (I did my own water test). I had read about people using silicone RTV and thought it was ok to use that to reattach the weatherstripping all around. Now I realize that's not the right way to attach weatherstripping - the classic weatherstrip adhesive never dries and can be cleaned more easily whereas the silicone dries permanently. I'm planning to use permatex silicone stripper to remove all the silicone and reinstall the weatherstripping the right way (it's bugging me that it's not on properly now).
Any advice on how to properly install the rear weatherstripping would be much appreciated.
Thanks!!
Art
Thanks!!
Art
