I'm having to replace the antenna mast in my 1994 Surf's power antenna. I want to be able to drop the antenna when the radio is on in case of the usual torrential downpours and high winds here on Okinawa.
Normally I would just drop a switch in to interrupt the power on signal (blue wire) from my aftermarket radio. The antenna won't go on until the radio turns on which is normal. However, when the radio is turned off, the antenna doesn't retract. It won't retract until the car is turned off.
I'm wondering if this a ground switch on the vehicle or some other crazy wiring. It should be the same as in a stateside 4Runner. Anyone tried this in their 4Runner?
