You will hear different opinions on the subject. My parts list consists of a high side fitting and a low side fitting.
First you need to find the leak, and to do this you can use an air compressor to put air into the system and use a spray bottle filled with soapy water to find the leak(s). 100 psi in the system will be enough. The most common leak in an auto a/c system is at one or both schrader valves.
After you have fixed your leak, and have installed new service fittings, vacuum the system down, add oil (if you need it) and charge it up.
The one thing that you need to look out for is a larger leak that has caused a significant loss of oil from the system. You'll know if you have one as there will be a nice black oily mess near the leak. The larger leaks will require no more than 2 oz. of PAG 46 oil to be put back into the system.
I will warn you, if you intend on following NLXTACY's advice of vacuuming all the oil out that you can, and gotmud's suggestion of flushing (which is good) you will miss on the oil capacity. You will have absolutely no idea how much oil is in the compressor. If you go the flush route, a step that was left out was pulling the compressor off and draining it of all the oil. You do not want to flush your compressor, and as gotmud mentioned, your dryer.
A replacement expansion valve will be exactly like the one you have now, if it cooled before, it will with 134a as well. So many replace it when it's not necessary. Same deal with the dryer, unless the compressor blew chunks, or the lines were disconnected for a long period of time, it's not a huge issue. They are cheap though, so why not replace it.
The o-rings, again, not a big issue unless you have opened the system, then you will want to replace the ones where you did.
So to recap:
Find and fix leak(s)
Install new fittings
Vacuum
Add any oil you may need ( if schrader valve leak, don't add any)
Charge.
This is exactly how I retroed my 91, my other cars, and many others. I do a/c.
