Hi,
I have a '97 80 that I picked up quite a few years ago where the PO did a bunch of work to it (3.5" Dobinson lift, bumpers, head gasket, knuckles, winch, etc). I am trying to determine if the VC has been removed also. I recently removed the front drive shaft to isolate a vibration issue and I locked the center diff when I did to test it drive it. I decided to see if the VC would lock up too, so I turned off the CDL and the truck wouldn't move when giving it gas. It would rev up and a bit of a screeching noise from the transfer case but no movement.
Is that normal with the VC installed? Is there a way to tell for sure if it is installed without taking apart the TC? The reason I ask is I live where we get a lot of snow and appreciate a limited slip center diff on snow/ice.
Thanks for the help.
