Yes we all know that aftermarket bumpers are pretty well thought out and in general are an excellent option to gain ground clearance. Slee makes a great bumper and as a replacement for the factory hitch Slee provides a surface mount hitch or in newer models a rather lightweight receiver style hitch that is not recommended to be used for towing.
So after only 1 year of wheeling this setup it is readily apparent that even the Slee hitch options are not ideal. The Slee surface mount hitches act more like a plow hook and I can visualize how absurd the factory hitch would be to wheel with.
So I started digging in a couple days ago. My Idea is to recycle a factory hitch to thru the bumper stout enough to use for recovering other vehicles with tow strap or trailering anything my engine/brakes are up to the task of moving/stopping.
(Edit - This is not a simple one
job. Please read entire thread, re-read it and then evaluate whether you have the Welding/Fabrication skills to perform a similar customization. )
My bumper was an early Slee model without the hole precut through the bumper for a receiver tube so I needed to cut a hole.
Welded up the old bolt holes in the bumper. Made some plugs for them first so hopefully not welded to the cross member as well.
Blot flanges were cut off an old factory FZJ80 hitch, inverted and switch sides so that they cradle the frame rails rather than hang down from them. One existing frame weld nut bolt hole is used for both Slee bumper brace and the reoriented hitch flange. Additional holes are drilled and tapped.
job. Please read entire thread, re-read it and then evaluate whether you have the Welding/Fabrication skills to perform a similar customization. )My bumper was an early Slee model without the hole precut through the bumper for a receiver tube so I needed to cut a hole.
