How to bench test oil level sensor?
Madison, NC
So I have the false low oil level light going on. A few weeks ago I pulled the sensor, cleaned it and reinstalled it. Light went off for about 20 miles then back on and has been consistently coming off and on since. One time while the light on I parked it and moved the sensor wire and it immediately went off. This led me to believe it was just a poor connection so I unclipped the sensor cleaned the contacts and I applied dielectric grease, a lot of dielectric grease. Light almost immediately came back on. Could I have applied to much grease and now it's bridging? Also I have tried testing the sensor by putting the leads on the 2 prongs and am getting continuity with the float both up and down. Am I testing it right?
My guess is you are testing correctly given its a make or break switch. I would suggest unpluging it and see if the light comes on determining if you problem is wiring or switch.
Having my light come on in the past on extreme down hills I wondered if the switch used mercury contacts.
If I remember right unpluging turns the light on , put a jumper wire in it and it should turn off. then see if moving the wire around might find a break some where. I might have a conectors and some wiring in my collection.
So a quick update, I picked up a used sensor and tested it and it also had continuity with the float both up and down just like the sensor that was already in the 80. Tested both the exact same way and got the same results for both. I had the time and thought what the hell I'll swap the new to me sensor in anyway and see what happens. It worked and the light has been off since Sunday. Leads me to believe that the problem was in the connection on the original sensor. Just glad to eliminate a dash light being on.
