How the plug look?
Guy I bought the truck from said the were replaced 13,000 miles ago. Gap is about .35
The color of the electrodes looks good and the interior tip of the porcelain looks like a clean burn. I'm not sure about the brown deposits in the outside of the porcelain. Possible blow-by between the porcelain and the metal body of the plug.
I would replace them with Denso plugs gapped to .8mm.
Denso and NGK are different manufacturers, like AC and Champion.
For some reason factory-assembled V6 heads have NGK plugs on one side and Denso plugs on the other. I don't know why.
Although Toyota uses both Denso and NGK plugs during assembly Denso is the exclusive replacement plug.
I think it was on TTORA I read that each side of the assembly line would install the spark plugs for that side. When one side ran dry of one brand, they would be re-stocked with the other. Both met the required specs so they were interchangeable.
