How much slip in 4Lo Reverse is normal?
(Kinda stupid title as the answer is probably none) Went to test my diff locks and noticed they don't lock in 4Lo (not new), only thing lit up on the dash was the two blinking lights. But also noticed something new. In the past when I put it in 4Lo the rig would jump either in forward or reverse when put in gear, but today I got some slip, most noticable in Reverse. Didn't get the usual torquey clunk, more of a lazy reverse, like something is slipping. Does the center diff slip when defective, or is this more likely my tranny slipping? (transfer and tranny fluids are at the correct levels and correct types). I tried a search, but got confused trying to read a long write up on the center diff. Suggestions on how to approach this?
Sounds like your diff locks aren't working because your center diff lock isn't engaging, per your statement 'only thing lit up on the dash was the two blinking lights'- you should have one for the CDL which should go solid when it engages, then the two blinking locker lights should go solid when they engage.
As for the tranny, is it slipping only when first going into gear, or if it's in reverse with the brake on and you let off the brake and give it gas? Might be normal to slip a bit when first engaging, but there shouldn't be any slip above ~1800 RPM after that.
Spike; yes, only two blinking lights next to each other; the ones that look like a diagram of the driveline; nothing else lights up (with the locking dial off). This is not new, just haven't had time to mess with it.
The new problem seems to be some slipping; I'll go out later today and try it again to get more data; it just seemed to slip when I gave it some gas and backed up, not like in the past when as soon as you shift into gear (while in 4Lo) the rig wants to jump from the extra torque.
