How much of a beating
Tacoma,WA
How much of a beating do I have to give the cylinder head to loosen it? I,m using a big rubber malet, what about a 2 x 4 and a hammer? Don't want to screw it up anymore than I have maybe already, I found out I didn't loosen the headbolts in sequence. Did I make a fatal mistake? :eek: Also should the the head come off straight up my engine is a 2f, any oil tubes to be concerned about? This is my first head job, and little perplexed. Thanks in advance. Hope to get this done before I ship out.
Haha. The problem is the rubber mallet. You'll be old and grey before that will get you anywhere! No oomph.
U need something skinny like a screwdriver, and wedge it between the head and the block with a real hammer. You will have to pull straight up to clear the two sleeves, one front, one rear [driver's side] that are sometimes referred to as dowels.
Look at the joint between head and block until you find a convenient place where an old screwdriver can wedge between them. Bop with a real hammer. Best to find a couple of places like that if you can Be careful but not too careful - this needs force, not finesse. All you're destroying by wedging like this is your old head gasket. Get the head moving (loose) before worrying about pulling it straight up. The tubes Mark mentioned are only about 1/2" long and once clear all you've got to do is muscle the head out of there without scratching up your paint.
It's off!!, what not to do.
Used the putty knife and destroyed the front tube, now I know where the are located now. When I lifted it off I was pleasantly suprized that it was just a blown head gasket, all the mahine shops told me I needed a valve job and be glad to do it for 1300+ bucks. Bought a full gasket set and slapped the head back on.( Just bought this baby and I want to drive now) but since I have the set I plan on getting a little dirty and replace the oil pan seal. Want to thank you guys in the forum, this place is awesome.
Be sure to put that new head gasket on the right way, there's a hole punched in the gasket that allows oil to get up to your rocker arms. Put the gasket on backwards and you'll have a dry top end. I found out the hard way.
a valve job for $1300.... now lol thats good for a few hahahaha . come on man they should do that for about $150 you did all the work of taking it off.
