How much does your shifter move?
Los Angeles, CA
I know the high-low range selector should move some, but I have 4-5 large speed humps I have to go over when I enter/leave my neighborhood, and it seems like my gear selector is moving too much.
Should it move at all?
How do I know if I have a bad transmission mount?
if I lightly touch the gear lever while I am driving there is some travel there. Is this normal?
Mine always moves in high range since the beginning. Not sure how to quantify that , but definitely noticeable when I put my hand on the shifter. Though it doesn't happen on every hump, and I can never find the pattern, but I am pretty sure it is normal. BTW, I never use the low range, so have no idea whether it will happen there.
Both my transmission shifter and transfer case shifts moves a bit over uneven terrain. The movements are not very visible, but I can definitely feel when I put my hands on them.
Mine move too, but I'm not worried......seems normal as the tranny and x-fer case mounting bushings compress.
That's odd, I can't remember ever noticing either of mine move. I almost never have my hand on the t-case shifter, but I regularly rest it on the tranny shifter and have never noticed it move under any circumstance that i can remember.
The transmission shifter is bolted to the floor pan. It should not move. The transfer case shifter is bolted to the top of the transmission housing and will move along with the engine/transmission/transfer. That's why it has a bellows around it.
Excessive movement of the transfer case shifter could indicate a failed motor mount. Under forward torque the shifter will move to the right as the motor lifts the left side.
So, should those of us that have movement in the shifter be worried? I understand the T-Case movement... but the shifter will move back and forth while going over bumps... If I have a mount broken somewhere, I'd like to fix it.
I checked the FSM, and with the retarded techs at the local Toyota dealer (useless), with no help.
Anyone have a test for transmission mounts?
I did ten years ago when I test-drove the car, but after all these years I almost forgot about it until now. :crybaby:
What does "back and forth" mean? Similar to "this way and that way"?
The engine/transmission/transfer case are all bolted together and there is a 3 point mounting system consisiting of the 2 motor mounts (one on either side) and the transmission cross-member. All 3 mounts have cusions that move so there is always movement in the drivetrain. What you are most likely describing is the linkage moving.
In a good bind in L I had the Tcase shifter get pushed into N.
I posted this on MUD and some said they had seen the same thing.
I would say that is the extreme side of the shifter moving.
What about at highway speeds? Should the transfer shifter be vibrating like an angry bee on steroids? Mine vibrates quite a lot though there's not a great range of movement.
:cool:
Mine buzzes at highway speeds, but I don't notice it. If it's really flogging about then have a look at your uni joints. But I suspect you'd notice other driveline vibes before that.
It doesn't 'flog' about and you'd only notice it if you put your finger or hand on it. Just thought it was quite a 'buzz' and wondered if it was normal. Other than that, since I put the rear propeller shaft in phase, it's all quite smooth. :cool:
