How much does this weigh?
Central GA
I'm debating whether or not to get the frame and tub dipped. The cost is $1.50 per pound.
What is the approximate weight of just the frame, minus axles and springs?
What does a tub and cowl, completely stripped, weigh?
Thanks in advance.
I dunno but check if its weight of item being dipped or weight of material dragged from dipping tank...I'm guessing you're talking about galvanizing or some sort of zinc???
You might want to reconsider having the tub hot-dipped. The frame seems like a good idea, if a bit pricy. IIRC, I've heard that hot-dipping the sheet metal will cause it to warp.
my frame wieght was 250lbs wiht all removed including the back crossmember and the two angle braces
just heavy enough that it takes 2 people to move it around
This would be the dip just to get rid of the accumulated paint , rust and gunk so I can start the patchwork without a lot of moaning and groaning. lol!
Where would you get it dipped????
I've been thinking about dipping mine (rather than sandblasting it), but I have NO idea where to look. What would I look for under the Yellow Pages/Online?? I don't even know what kind of buisiness would do it.
I think dipping would get more of the nooks and crannies that a blaster can't get. Especially getting the inside of the boxed parts of the frame.
little bit of room, and time
look at caustic solution, or electrolysis (SP).
most strippers use a caustic based solution, you can do it yourself if you wanted.
Well, I had thought about doing it myself until one of my patients showed me some chemical burns on his hands and arms from an accidental spill of the muriatic acid. 1 year later and some have still not healed so its skin graft time for him. There are some things that may not be worth a DIY attempt.
I'd still like to know how much a stock tob and cowl weighs.
