How much does my 80 weight?
Fairfax, VA
I know there is threads about fully loaded 80 series weighing in at almost 7k lbs. My question is, a few years ago I went to a weight station for something, dont remember what, and the guy said 5980lbs, with me in it. That was when the truck was on 33"s and no winch. So as my trucks sits now, its on 35 BFG's, aloy wheels, ARB front with winch, home made spare tire carrier with spare( same size), maybe a 100lbs of gear in the back at all times, dual batteries, and my 6'4 220 butt. I told my buddy how much the weight station said it weighs, and he said I was on crack, " No way your truck weighs that much"!! So what do you guys think? Anyone with a similar setup know what theirs weighs?
:cheers:
I weighed mine once at a dump. Arb front wiht 12k winch and kaymar rear and 33's. 5052 or something like that.
I'd wager you are in the 6200lb range with you and a fuel tank of gas.
These rigs are h-e-a-v-y. They're pretty compact and that throws a lot of people off, but the LC80s have thicker body panels, MUCH heavier frames and suspension and axles than most rigs in it's class, so they are FAR heavier than they look on the outside.
Curb weight, with absolutely NOTHING in it, is 4760lbs. I doubt anyone has seen that weight as that's minus any fuel or passengers or any gear of any kind and totally stock.
My rig when bone stock, with fuel, but no passengers or gear, weighed 5100lbs
Today it weighes in the range of 6500-6900lbs depending on the gear or number of passengers I'm carrying.
By the way, maximum gross weight is suppose to be 6470lbs, but people regularly go much higher with zero issues. Good thing these truly are "heavy" duty and way over engineered.
Mine ways 5500lbs. Stock except Slee Sliders, 33's, OME 2.5 Med Lift, No spare (in garage unless wheeling). That is with a 1/2 tank of gas.
Just curious if you have a sun/moon roof? It adds a bunch of unwanted weight.
Yes mine has a moon-sun roof. Didnt know it had so much weight?
I wonder how accurate the scales are at the local dump? They weigh you before and after, then hit you with a bill.
I cross scales often on deliveries, some of my customers have them at the security stations. Depending in the load of tools for delivery/pickup and fuel, my rig weighs between 5300-5500lb, my guess would be ~5200lb empty. '96 LX, with ARB front, 4x4Labs rear, 37" tires, etc.
The last time I had mine on the scale it was 6,240 lbs with a 50/50 balance, 3,120 lbs per axle.
Pretty accurate from what i can tell. One of clients is the local transfer/dump/labdfill. 20lbs off sure. But never a 100lbs. They run 5 scales that are pretty close. just my .02.
Ours fully loaded and ready to head out :D
weight a second
weight just a second , thats heavy, no weigh dude! I wonder how much mine ways?:lol:
