I have Slee's 4 inch front springs with his castor plates. My last alignment specs were 4.6 and 4.8 degrees (stock range 2-4 degrees). Front ARB bumper, winch and dual batteries. I need to dial out some castor, steering is very heavy and my front d-line has a nasty vibration. I have Slee's DC front shaft, I have tried my stock front shaft, both out of phase (stock) and in phase, none of the combos have helped.
I think because of my high castor numbers, the driveshaft flanges are out of spec. (I have dropped the front shaft and it is butter smooth).
I was thinking of switching out the front castor plates for bushings to try and dial out some castor. So which should I go for, OME yellows or Slee blues?
Jack
Jack
