The Panasonic in my 2000 lasted almost 7 years with a little over 90k.
Since these things are that good why don't owners just replace with the OEM Panasonic?
Just about everything is that good from the factory on a UZJ100. Why do we change anything? Usually to tailor the vehicle towards our more specific needs.
Sure a battery is awesome from factory, but maybe we need a dual setup or a deeper cycle. Maybe they have a bunch of inverters in the car and need more amps per hour or something.
I'm planning to try the big Odyssey, will order it this weekend.
As far as keeping the battery from sliding around, the guy at west coast batteries suggested removing the battery from the metal jacket bucket using a putty knife (it's glued in there) and bolting the bucket down to become the battery tray. One could use a piece of plywood w/ a hole drilled inside it so the bolt is flush and doesn't poke into the battery. Another possibility is getting a group 30 cast aluminum battery tray base. I also got a 3A BCSC 3-stage charger/trickle charger since the vehicle sometimes isn't driven for a few weeks.
Just ordered my Odyssey. I ended getting the pc1700MJT from west coast batteries ($198.95+shipping, better than any of the prices I found on the web). The other options were the pc1500 (but terminals are reversed and they don't make one yet non-reversed) and the pc1700/65 (group 65 size, terminals also reversed). The PC1700/65 measures 11.92 x 7.17 x 7.58, so closer to the OEM size (about 12 x 6.75 x 7.8).
http://shopping.rexmar.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=batboxrex30
BTW, he recommended only using metal jacket batteries if it's in the engine compartment due to heat shielding.
So why didn't you get a OEM battery?
I couldn't find anyone who sells the Panasonic battery.
NMuzj100 said:(PM to the cruiserdan of American Toyota)
Dan,
Is it possible to buy the original equipment battery that comes with a new 100?
Thanks, Matthew
cruiserdan said:Nope, only in a new vehicle.
If they were imported loose the hazmat containment costs and tariffs would push the cost to probably over 400 bucks a copy.
Nobody wants to spend that much....![]()
OEM/1997/130K
I will be replacing the battery this weekend. I've been struggling with terminal corrosion for the past month and I'm tired of cleaning them.
Ditto.
