how high?
Omaha, NE
Good morning all! I need to burp my cooling system I have tried on the hill near my house but I do not think it is the right incline. How high do I need the front end to get the best results? Also does it matter if the coolant is hot or cold to begin with?
Thanks,
Cory
Sorry if this is a silly question btw.
You can always remove the rear wheels and lower the back axle with a jack. I don't think an incline is required, it just makes things easier.
If you're going to run the engine with the radiator cap off, I'd start cold and go until the thermostat opens and you can see coolant moving around. I'm sure others will chime in.
never had to "burp" mine. I just fill it, then start it cold with the cap off. Once the thermostat opens up it starts taking coolant and releasing air. Keep doing that until it stops taking coolant. Then add some to the overflow and done.
I use car ramps. You can also use a curb.
The idea is to get the top of the radiator higher than the heater valve by the firewall.
Make sure your heat setting is on high (fan sped doesn't matter) so that your heater valve is OPEN.
Start the truck cold, place up on ramps or on the curb, keep the radiator cap OFF until the fluid starts to swell and overflow the radiator neck.
Fill the overflow tank to the correct level and take it for a drive up to full temp and highway speeds.
Bring it back and park it on the ramps / curb until it is completely cold again. Lather, rinse, repeat. until there is no more air in the radiator and the level in the overflow tank has stabilized. I did that part for 5 days to/from work each day.
Thanks everyone I've been having lame heat since swapping heater cores. Just couldn't figure the burp out. Your knowledge is appreciated!
I usually do it with the vehicle level and fill it till it's full then squeeze on the upper radiator hose abunch to get some air out. then fill it again and start the engine with the heat on and keep filling and squeezing till it's full then fill the overflow. Drive it a couple hot and cold cycles then fill it the overflow again if needed and it's all good
