Just got my truck aligned following the lift install. How do these look to you guys? All are within spec according to the shop. I’ve already got control arms but haven’t I stalled them yet. I’d prefer to keep as many OEM parts as possible.
Cross-caster helps keep the vehicle straight if you have a lot of crown in your roads. Otherwise if they are the same you will end up holding the steering wheel cockeyed to drive straight. How much you need depends on where you liveI think it's odd the caster is so much different right to left, I would have thought the shop would have made then the same, or as close to the same as possible.
I see you're in the green but on the edge like me without the upper control arms.
I prefer a bit more caster but those look good for a stock (or low lift) setupJust got my truck aligned following the lift install. How do these look to you guys? All are within spec according to the shop. I’ve already got control arms but haven’t I stalled them yet. I’d prefer to keep as many OEM parts as possible.
Settling will help. You may just need adjustable UCAs thoughYours look good. I think mine are bad on paper. But the car drives fine. 2"+ lift and stock UCA. He said he cant add any more caster and he will try again after the springs settle. View attachment 2216939
Ideally yes, but they are very expensive for what they are.Settling will help. You may just need adjustable UCAs though
Jason has ones made by Tough Dog for $500 per pair. I think I paid $530 for my SPCsIdeally yes, but they are very expensive for what they are.
Did anyone try cutting and welding the stock UCA for proper alignment? seems like a really easy thing to do if you can weld.
Still so expensive I don't understand why. It's simple bent tube steel with a pair of bushings and a spherical bearing/uniball. Is there a huge mark up or am I underestimating the complexity of the UCAs?Jason has ones made by Tough Dog for $500 per pair. I think I paid $530 for my SPCs
I don't know, but Toyota factory UCAs are similarly priced, IIRC.Still so expensive I don't understand why. It's simple bent tube steel with a pair of bushings and a spherical bearing/uniball. Is there a huge mark up or am I underestimating the complexity of the UCAs?
Theirs are even more cheaply made, just stamped steel. This makes zero sense to me.I don't know, but Toyota factory UCAs are similarly priced, IIRC.
