how do i switch center consold lids?
Simple question. I have two center console assemblies. One has the "base model" or older flat lid with no padding or storage in the lid. The other has the taller lid with padding and a 2nd storage area. Any idea how to remove theses? I think the tricky part is the arms that extend down into the center console .
Not in the 80 but seems like you accessed the hinge from inside the lower/base underside. So you had to flip it upside down (meaning removal from floor) -to get at a couple phillips/JIS screws.
But that's from memory & we've already established I'm on nighttime thera-flu @ 11AM - the OTC RX equivalent of 'It's 5 o'clock somewhere'.
Are you referring to the LX450 console (the one that has the two compartments)?
If you just want to temporarily remove the top two lids you can slide off the tiny snap rings that hold the top of the arms onto the lid. They are only about 1/4" across and are darn near invisible. Then just push the arm pins sideways and they will pop out. The arms can remain in the slot of the lower console until you want to reattach. Unscrewing the hinge should be pretty straightforward and accessible without removing the console.
If you want the arms out permanently, then you need to follow @LINUS 's instructions above.
The plastic arms end with a hook. Unscrew the two mounting screws, pull the lid up until it catches. You’ll have to wiggle a bit towards the engine to get the hooks out.
