Hi everyone....long time member, haven't posted in years. If you want to skip the fluff, just go straight to the last line to see if you can help me out....thank you in advance.
Have a mostly 74ish FJ40 that I resurrected out of a farmers field some 8 years ago. Everything has been a fun challenge until now. alot of cleaning, grinding, painting, welding, axles, spring over, engine tune, new cage...basically remodeled everything, but I am not skilled enough to make it pretty, I am not, nor is my franken-cruiser a candidate for restoration, it is just a fun weekend cruiser for myself and the family to enjoy bombing around in. It will always be the ugliest unit at any club meet, which suits me just fine.
Suffice to say, the wiring was an absolute disaster when I got it, with splices and bad grounds as far as the arm can reach. I managed to get it running reliably and had no issues for a few years while I enjoyed blasting around and was able to work on other issues.
One evening, about a year ago, my lights stopped working and it was nighttime and I started looking around for the bad ground that was causing the issue. Eventually I found it buried somewhere under the dash, but replacing one issue for another, my windshield wipers stopped working, along with my front blower (heat).
I have looked at wiring diagrams and traced wires as far as I can reach and see....everything worked as it should before I started trying to sort out the light issue. I have clearly unhooked a bad splice or a ground somewhere and I will never find the one issue that I need to reconnect. I have realized that now....after prob 100 hrs of trying different things, multimetering everything etc I have given up trying to fix some ancient splice....on my previous LC I had similar issues and just ripped every wire out and put in a new harness. Had it start to finish done in a weekend, but that was 25 years ago and I had nothing but time and supple joints back then....now I dont know if I am up for a full rewire, altho the garage rage has def pushed me to the precipice of doing so.
Ok, enough pre-amble....I am wondering if anyone has the "cheat code" that can explain or show me how to hotwire my wipers off a simple toggle switch. I have tried running 12v power to the switch, to the motor itself, grounding it various ways...it seems I have no power going to the original switch either, and no power going to the motor when using the existing wiring setup, so I am looking to just do it direct. I previously had to do this with my old 67 and it was fine, it had the 2 individual motors and it was a snap. My current wipers are top mounted, with the main motor on the passenger side and the smaller motor driver side, connected via thick cord. All wiring to the pass side and a 4 point plug. I have continuity thru everything but the motor does not respond when I direct wire 12v to it. I am either doing something wrong or the motor coincidentally died in the last year while I have been trying to get it going. I am certain the motors work, I am just not providing the power source correctly.
Edit. I forgot to mention…one of the biggest issues is the stock harness itself is so goddang short, it barely reaches the switch as it’s, so I have very little wiggle room in there to see what the problem is. A lot of telescoping mirrors, angles and flashlights to source things out. Wish there was another foot of line on it but it is what it is.
If you skipped to here, All that to ask, if anyone has a wiring diagram or a blue collar explanation of how I can hardwire my wipers off a toggle switch. I can attach photo's if required.
