Hot water shower 12 V pump sugestions
flagstaff, Az , 86004
Website
www.adventuredriven.com
Hello All
I have a heat exchanger hot water shower system I bought from Kurt, My water pump is broke again and I wondered if you guys may know of a 12Volt pump that is portable that is good quality? I want to drop the pump in a 5 gallon bucket in the shower enclosure that will be set up close to the cruiser. Looking for something a little more rugged than the pump I have. I have found this one and did not know if it was junk or not
http://www.ebay.com/itm/221089486207?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Any ideas is welcome :)
Thanks
Sethro
After using and not being all that enamored with the pump that came with my Helton kit...I bought a Flojet 12v water pump (Shurflo, Aquajet, Flojet...they're all very similar). Works great.
I get higher pressure and lower volume that makes super efficient use of water that is typically limited supply. And if we have a water source like a clear water stream or lake it has enough pull if you need to use longer feed hose...
Although I keep mine in cab you could probably mount it under hood...just be sure to blow it out before winter/freezing temps.
