Hot starting question
nw montana
I realize this has been discussed lots and consensus is to install carb cooling fan...
But if I park it blazing hot and don’t try to start it till next cool morning, it starts in 1 second. If the manifold is boiling off the gas in the bowl why would it instantly start next am.
Yesterday parked in hot parking lots for 15 minutes required 30 seconds of starter.
I realize the bowl is vented and vapor lock shouldn’t be happening.
How does the 8 hours of cooling fill the bowl without the fuel pump running?
Can’t find the thread where someone solved the problem with temperature sensor fan
Thanks
Eight hours of cooling doesn't refill the float bowl because it was never empty. When you park with a hot engine on a hot day the fuel in the bowl evaporates faster than when cool. But it doesn't all evaporate. Enough can (and does) evaporate to fill the intake with enough fuel vapor to create an overly rich and incombustible mixture. The reason it starts easily the next morning is because the fuel vapor has had time to dissipate.
Next time you do a "hot start" try holding the gas pedal down while cranking. This does two things: prevents the carb from adding more fuel (other than the shot from the accelerator pump) and allows more airflow through the engine to "flush out" the over-rich mixture. After a few seconds of cranking the mixture should dilute enough with fresh air to fire. When it does, release the gas pedal and Bob's your uncle. This method works well for me on both the 40 and 60, neither of which have carb cooling fans installed.
Good explanation. Thanks
Will try the full pedal.
The full pedal without pumping definitely helps. It still takes 5-10 seconds unlike cold starts which are immediate. Looks like there’s no need for a carb fan for me. Thanks for the insight, the explanation and assistance. Once again Mud to the rescue.
@ArizonaFJ nailed it. This is from a reproduction owners manual for my '76 CA spec. 40 with a carb cooling fan.
When I first got my rig I had the same problem. Two things helped cure it:
I read my new/old owners manual front to back.
I installed a torque reduction starter from an FJ60. (less cranking)
That would contribute to the reduced air in your carb's fuel mix, and make your fuel vaporize at a lower temp.
I keep toying with the idea of a kill switch for the idle circuit solenoid as a partial antitheft device. But, that might also work to lean out a hot start with, or without, the throttle depressed?
