Hot FJ60
Waco, Tx
Website
www.aggiefj60.wordpress.com
I'm cruising down Hwy 6 in TX, going 70mph, but it seems that my engine doesn't think that's very cool...can y'all tell me if this is normal temp at that speed? I've replaced my fan clutch, coolant, and thermostat within the year, other than no upgrades or repairs to cooling related functions of the mighty 2F.
-Hudson
Is this a new thing? Under highway conditions only or all the time? Assuming so or you wouldn't have brought it up.
My 62 runs about 1/3 of the way up the gauge, except when I get a weird spike and the temp and fuel shoot up for a while simultaneously. Apparently that's somewhat commonplace.. Is that normal position for your oil pressure? That's higher than mine by about the same as your temp gauge compared to mine under normal conditions. Maybe you have a bad connection in the cluster that's effecting both?
Can't say if that temp is normal. Might be for your truck with its wiring and that particular gauge, might not be. Factory gauges can be off and are to me at least just an indicator that something has changed, not an absolute measurement.
When I have a gauge I don't believe or have reason to mistrust and things check out otherwise I break out the IR temp gun and check a few places, head, water neck, etc.
I've trusted the gauges since I've owned the truck, but never put a numerical temperature to the analog estimates. It's on my to-do list. I just recently began experiencing the thrill of 70mph again after replacing my secondary jet diaphragm...prior to that the needle would sit at the halfway mark when I cruised at a cool 60mph. I haven't taken the radiator out to flush it or flow check, so I'll start there. Hopefully it's an easy fix like that. The old girl is probably just clogged up.
Read about "burping" on here.
Make the fill port the highest in the system. Top off the system. Then run while constantly massaging the upper radiator hose and adding fluid as needed. Make sure it reaches operating temp. I have used this method many times with great results.
Ethelyne glycol coolant and distilled water of your choice. ;)
If the gauge shows 3/4 at 70, I'm wondering what it shows at light throttle at 35-40 mph in 3rd gear when it typically runs its coolest.
If the needle drops when reducing throttle and speed, then yes, it's running warmer when it's at 3/4.
One of the manuals state that if the needle is within the white zone, then the engine is operating at the "correct" temperature... Whatever temp Toyota deemed that was ...
At 35 mph in 3rd, temp reads about 1/3. I've burped the system and got it topped off, but the drop in running temp at 70mph was very little. I'm trying to run it cooler to avoid pinging when heading up hills, and avoid overheating if I come to a sudden stop on the highway. If I have a good mile or so to downshift into third, my temp will usually level off at the halfway mark. It's the sudden stops that scare me.
.... and avoid overheating if I come to a sudden stop on the highway. ... It's the sudden stops that scare me.
The engine doesn't get hotter when coming to an abrupt stop-to-idle after traveling at highway speeds, only the coolant does. And that doesn't really matter.
The temperature sender in the engine is measuring the temperature of the COOLANT which was obviously heated by the metal of the engine, which was obviously heated by the burning fuel inside the cylinders. It is not directly measuring the temp of the metal engine, nor the temperature of the cylinder walls nor head.
There is a considerable lag time between when the fuel ignites, to when the metal (engine) gets hot, to when the coolant heats up, and finally when the sender detects a change in temp.
Heat in the engine starts inside the combustion chamber the instant the spark ignites the fuel/air mixture. It is the burning plasma that transfers heat to the engine. Since heat generation is proportional to the amount of fuel in the mixture, the INSTANT the throttle is reduced, the cylinder walls, pistons and head begin to cool down. This starts happening in less than a second regardless of RPM or the efficiency of the cooling system.
When the vehicle is traveling fast on the hwy, the engine is creating a lot of heat, but the air is also flowing fast through the radiator, cooling it down, and the water pump is pumping coolant quickly through the engine.
When the vehicle suddenly comes to a stop and idles after a fast run, the cylinder walls, pistons and combustion chamber start cooling down immediately because the source of the heat has been greatly diminished with the release of the throttle.
But the COOLANT temperature continues to rise as it is still soaking up OLD heat (latent heat) that was generated in the past that is finally getting around to being transferred through the metal to the coolant.
That temperature is old news of times gone by. It doesn't matter anymore except for curiousity's sake.
And since at idle, the water pump circulates the coolant more slowly, and there is less air flowing through the radiator than before, AND the temperature sender on the 2F is all the way in the back of the engine,... the temperature of the coolant at that location reflects in a very inaccurate way, a general idea of how hot the engine WAS "a long time ago".
Ignore it under these circumstances. The engine isn't getting hotter.
always good to know the engine temp in numerical values F.... aftermarket temp gauge. Based on the pic I would say you have some concern but what is the actual temp if F of the engine at that noted position on the gauge? Did the radiator boil over or have any other symptoms of running hot?
What section of 6 are you cruising on? I run between College Station and Bremond/Franklin area daily!
Also had a temperature issue yesterday, hopefully the new T-stat will fix it.
I had this issue that eventually got worse, smog pump loosened up letting the belt slip just enough to not fully spin the water pump. That was my fault though, this helped for about a year then my radiator was getting clogged causing poor cooling, now mine runs right at halfway most of the time, real hot day it will creep up a little bit but not quite that high, at that mark on your gauge I'd say its getting a little warmer than normal but not too bad. I'd consider a radiator...csf brand are great
