Hose part number
I noticed earlier i was leaking coolant from this hose right below the crank on my 3FE. Anyone know what the part number on it is? I tried looking at some diagrams but couldnt find it. Its not leaking as bad as it looks in the photo. I spilled some from the upper radiator hose, but it is leaking. The goopy looking stuff where it mixed with oil is from the hose. all the little drops are from my spill
Do you think this is a coolant hose because it enters the bottom of the radiator?
(I do NOT mean that to sound like a smart-@ss)
I believe this is the Trans Cooler Tube. See this page: 1992 TOYOTA LAND CRUISER 4000CC OIL COOLER & TUBE (ATM)
32921D P/N is 32942-60080 HOSE(FOR OIL COOLER INLET) Looks to be ~$100 Yikes! I have a 3FE too!
no its not my tranny cooler hoses, those are the two hoses zip tied together off to the side. This hose runs from the water pump down then to the back.
looks like it is actually pipe. Someone can correct me if im wrong but i believe its part 15777B. Unless my pipe is leaking its gotta be coming from somewhere else then i guess. Maybe part 15777, i replaced that hose when i did the water pump a year back, maybe i didnt tighten it enough. Well have to look more when its daylight.
Bingo, looks like you found it!
That looks like the correct clamp and sleeve-thingy.
Check the hoses/clamps on either end of that tube. Might be time to replace the 15777/A Hoses and 15777D clamps given the age of the vehicle.
15777B is the hard pipe shown in the picture. The clamp in the middle has a rubber pad that is swollen from being soaked in oil/coolant(I know because I was just in there. Pipe is probably fine. Like Golgo said, check the rubber hoses on each end(15777 qty(2))
Is general consensus that the oil is front front main seal? Coolant I'm sure is from not tight enough hose clamp.
