horn wiring
Brunei
the pics are from my 1980 40, my horn doesnt work, i checked all the wiring up to the steering column and everythings fine..
i couldnt get to open the steering wheel though coz the screws r rusted.. then i noticed the steering wheel looks as if there is nothing connecting the horn switch in the steering wheel down to the steering column..
or am i wrong?:confused:
Hi Roddie, If your steering wheel is like mine (84 model) then you should have a brass contact ring on the wheel side of the connection. (I'm doing this from memory cos I don't have my rig in front of me but I do have the wheel, lol!) On the column side you should have some small brass tabs that are sprung against the brass ring on the other side so that the wheel can rotate and electrical current can be maintained between the horn on the wheel and the wiring on the column. Check the tabs to see if they are touching the ring. They also may be dirty so if you are able to remove the wheel then give them a good clean up. Not sure what horn button(s) you have but also check the contacts there too. Mine has three buttons, one on each spoke of the wheel and they have a brass contact tab behind each one. You may like to clean those up as well.
If that doesn't work then you are more than welcome to mine as I went for the after market wheel and my stock wheel is just gathering dust and if your lucky there might be a redback or two living inside!. Didn't fancy having the feel of driving a bus while going soft-top!!!
Good luck.
i knew i was missing sumthing, in the pic you can see there are empty grooves.. maybe thats where the brass tabs are supposed to be.. are there any sites that show the steering wheel assembly? i went to sor and couldnt find a close up view of it.. t
should there be a brass tab on the steering column 2? coz it isnt there also:confused:
Yes there should be a brass ring about 2" across on your wheel and brass tabs on your column that contact with it across the gap between wheel and coulumn.
