The Horn now only works when you push in just the right spot.
What up with that?
What up with that?
Pull off the steering wheel and find out.
All the workings of it are right there. Probably just need to clean a contact or something...
The correct answer to this question hinges entirely on the vehicle in question. Since the vehicle has not been identified only a fool would follow any of the above suggestions. To assume that the vehicle in question is the vehicle in the sig line would also be foolish.
Ripping into the steering wheel on an airbag-equipped vehicle is a potentially dangerous situation that should only be attempted by someone who knows the lay of the land.........
Do I use my hammer, catspaw, or the sawszall to remove it?
I just thought that most likely someone has had this happen on an 80 and could tell me what it probly is.
You need to remove the steering wheel and then remove the combination switch and replace the horn contact pin (84312-12040
