Horn problem...ground at wheel
San Jose CA
My horn won't blow. Traced the issue to NO ground at the horn switches. Apparently the steering wheel shaft is not grounded. The steering box IS grounded. The shaft is connected through the flex coupling at the bottom of the shaft, but no ground through the steering box. Connection between horn relay and the horn switches are OK. Horn blows if the switches are jumped to ground.
So, how the heck does the shaft get grounded?
'71 Cruiser with a '74 steering box/column
It did work some time ago, but....
There was a small metal 'Reid'/spring that bridges from the back of the steering wheel to a copper ring behind it. Pull the wheel and check if it is still there.
You said the steering box is grounded and the steering shaft is connected through the flex coupling. Is there a wire connected from a bolt on the box side of the coupling to a bolt/nut that's part of the shaft? There's not always an electrical connection made through the rubber of the coupler.
There is no wire on the box side of the coupling. Seems like that would be wrapped when the shaft turns while steering. he steering box is grounded. The shaft is grounded through the coupling. The ring at the top of the shaft is grounded. But there's no ground connection to the horn switches.I attached a picture of the top of the shaft. There are no springs or brushes, or attachment points for them visible anywhere that I can see.
So, how is the horn switch group connected to the grounded shaft?
That's right. I had used a short wire to connect through the flex in my '65 but Toyota uses a copper gizmo to do it with one of the bolts. Either way works. Also I just put the column back together in my '78 VW camper and they use an actual OEM wire. Sorry for the confusion about it, but the point remains that the column needs grounding and you show a photo with your NO ground pointer to the column? I'm not sure how the bottom of the column above the flex coupler can be grounded but the top of the column not be as they're one long piece of steel, or somehow not?
Your steering wheel has a central horn button? Or is it after the change to three little microswitch buttons on the steering wheel spokes?
"Horn blows if the switches are jumped to ground."
How did you do that? From where to ground?
Did you check the sliding contact that touches the back of the steering wheel?
Rudi
Hmm. The steering box IS grounded. The steering wheel shaft IS connected through the flex coupling, but apparently there's no electrical connection inside the steering box between the shaft and the box.
The picture of the turn signal (white plastic) shows the flat spring that connects the horn relay wire to the 3 microswitch horn buttons on the steering wheel.
There are no brushes that connect the shaft to
Rudi
That was my issue. The sliding contact that touches the copper back of the steering wheel was broken off. Had to replace.
Thanks to @bj40green for the info and picture of the sliding contact. Fabbed a piece of copper from a pipe strap to replace the broken sliding contact. Reassembled everything and now I have a working horn. Only issue I had was making sure that the new sliding contact did not come into contact with the grounded steering column. Otherwise my horns were on permanently. Doing horn work early in the morning probably did not make me a favorite with the neighbors or my daughter.
