1971 fj40 I'm trying to build up a working horn. I have part # 5,3,7,8,1. I just ordered #4 and I believe #2 is just a rubber washer. I also have #6 but no wire. I know there is supposed to be a wire exiting the steering tube to hook into harness, but where does the upward end of the wire connect to? it looks like there is a hole in the end of the horn ring where the wire would protrude from but what then? confusing.....
4 is the rubber insulator/washer, 2 is a big steel washer. When #1 is pushed it forces the outer edge of #3 to overcome the rubber insulator(#4) and make contact with the outer edge of #5.
Not sure what to do about the missing wire on #6. Possibly solder a wire on.
Do you have #11?
@CSteppe82 just went through this. Should be some helpful pics in his recent question. Also, I’ve posted 71 (horn button/ horn contact ring / horn contact spring / horn insulator) pictures. You can enter my handle in “Posted by member:” and various query combo’s if you want pictures.
