Anyone tried aftermarket or should I go with OEM?
Amazon, strong arm I think is the brand
I use these as well. So far so good.
I just recently replaced strongarm struts with these
Two Front Hood Gas Charged Lift Supports With Four Replacement Studs for 1998-2007 Toyota Land Cruiser, 1998-2007 Lexus LX470. Left and Right Side. WGS-394-2 https://www.amazon.com/dp/B01EXHNK6Q?tag=ihco-20
As previously stated strongarm shocks are shorter and the new shocks definitely raise the hood higher, in fact these raise the hood for you after releasing the latch, I just let go
"at least for the very short time I've had them - have held the hood up many times so far."
What do you mean u took them off early why???
Let me try these seems reasonably priced - thanks for the clearance advice I did not realize this could be an issue. You cannot go wrong with hood rising by itself![]()
I need to replace both the hood and tailgate ones on my truck, as the current ones are pretty limp. I purchased this set off eBay, because it had both.
4 Hood+Tailgate Lift Supports Gas Struts for Lexus LX470 Toyota Landcruiser 100 | eBay
I’ll post an update on how they work, once I receive and install them. I’m not expecting much, but for $22 I figured I’d take a chance. Anything is better than the ones currently on my truck (hood barely stays up).
How did the struts turn out?
