Hood alignment
Draper, UT
I picked up a 92 recently and today I fixed a few thing that needed fixing. The one thing that is bothering me and I am having trouble with is the hood alignment.
The rear passenger corner of the hood is sitting up almost .5" too high. I removed the hood to see if I could lower the passenger firewall mount. What I found is that only 2 of the 4 holes on the hinge are elongated, which means lowering doesn't appear to be an option...unless I elongate the other 2 holes.
Has anyone else dealt with this before?
Mine is the same way on the DS. Sticks up a good bit and adjusting bolts doesn't make any difference. I made a thread in Paint & Body which got few responses, mostly saying I just had a bent hinge, which I accepted because I know the truck was wrecked before. Maybe your hinge is bent too?
In the past someone probably left something sitting on the inner lip of the fender or cowl and attempted to close the hood. That is a lot of leverage available to bend the hinge, and the result would be pretty much exactly what you have.
I'd try to find a known good hinge and swap out. Pretty confident that'll fix your problem.
Agree, hinge bent by someone dropping the hood with something lying in the gutter. Just a note on alignment, give yourself plenty of clearance at the rear where realigning if it has to be done in the cold, if not then that sheet of metal will expand in the summer and take off the paint along the edge of the grill at the bottom of the screen...ask me how I know.
regards
Dave
