Homemade Coil Spacers
Southern Minnesota
I've done quite alot of searching, and didnt find much on this topic. I know I am like alot of you in the sense that I want to do everything I can on my own. Not too many people seem to be making there own coil spacers though, maybe its due to their relatively low cost or maybe its just impractical.
I just installed my lift today, and decided against a spacer, but now that its on, I think I want more. Typical eh? Well here are my thoughts. I have access to some high quality poly (used alot around an ice arena), and thought of fabbing my own up. I know it may take more time than its worth, but its more about keeping me busy than saving the $75. The poly I want to use is 1.25" thick and VERY high density stuff. I was going to just go off of the MAF design and fit them to my old, loose coils so time is of no concern. I only want 1" overall so I think its do-able with the 1.25" poly.
Anyone else made any? Would like some input, I think it will take ALOT of time, but once again, its just going to be time I'd be on mud anyhow:p
Let me know what you have done/what you think. I'll post pics along the way.
If I was to fab up my own coil spacer I would use metal so I could attach the spacer to the bump stop similar to the metal tec ones.
Here are some that I made for the back. I am in the process of installing some others in the front.
The back are two disks and also serve as the top for the air back to push on.
My front ones are 4 inch weld on black plastic pipe fittings. The outside diamiter is about 4 3/4" and will fit nicely inside of the five inch coils and the flange will space the spring down 1". I expect I could put one on the top and one on the bottom. The shock has to go through the middle on the front of mine.
Kevin those hardly count as "homemade" and I still smile every time I look at them in my wheel wells. Over two years later the finish is intact and the function is flawless.
You are still a "BAD DUDE"........:lol:
Kevin those hardly count as "homemade" ...
True, they were made at my shop, but spend way too much time here and think of it as home.:o I guess that I hang with way too many people, hobbyists that have machines, mostly at home, so take then for granted.
Anyway, I hope that the making them pix give some ideas. With the price of the man-it-aint-free spacers, it's hard to justify making them, other than just for giggles, to say I did or to learn something and for me that's what a hobby is about.
If made from plastic they could be made with woodworking tools. Like, a couple of big hole saws, roto-zip or router to cut the circles, then profile in a router table?
But then they wouldn't be "weapons-grade".........:lol:
Spent some time working on them today, total of 1.5 hours from the time I starting to completing the install. They install just like the metal tech spacers. I just traced the bumpstop onto the poly and cut with a jigsaw. Had some good quality hardware laying around that was perfect for the job. It was tough to cut, but I think with a good router I could have had really clean edges and a better "finished product". They are good enough for me though.
Here are some pics
You're right, if you had a router, and a flush trim bit with a follower bearing, it would be easy to smooth those sides out and make it the same size as the bump-stop below.
What is the name of that material, or who or where can I get some. I need to make a set of those.
Those turned out nice.
Here are some pics
Looks good, a couple of notes: The over the cone type spacers reduce the total travel, can be an issue with short shocks. Looks like you used through bolts? I found connector nuts and studs or bolts and to be an easier solution. Like in post #26 in this thread;
https://forum.ih8mud.com/az-copper-state-cruisers/79654-csc-brand-fj80-front-spacers.html
Has anyone put them in the rear?
Send me a PM, I can send you some it'd be easier than trying to find just a small amount. I'm pretty sure its polycarbonate which makes it heat/impact resistant. Have a few different colors also.
I am going to make a set for the rear when I get some time. I want to use the same material, just with a 10mm poly ring , mounted onto the poly "donut spacer" I make, to keep it seated inside the coil.
Shoot out some pics when you finish them. I was wanting to use steel for longevity sake. I haven't looked under there to much yet to see what the build will intail. I'll post pics when I get around to the build.
the rear bump stops are not connected with fasteners, they appear to be welding. I didn't want to mess with removing any welds that the factory placed, so just wanted to do a MAF style spacer. I'll definitely sot pics when the back is done. Maybe it will inspire more people to not throw away money when these can be built with little time/effort.....and its fun none the less! If anyone wants some material (poly) to make some spacers I have left overs...just pay shipping it cant be much...
